Brian 27 OB
- Sep 8, 2020
- C-28
- Day Tripper
First boat I have owned without an exhaust fan in the head. Not a complaint or really a big deal, but was thinking of adding a small ventilator fan to exhaust moisture after a shower. Vetus makes one that requires a 3” hole and it is only 2.5” tall, easily placed high up on the partition and a small louver could cover the discharge side. That space really steams up and opening the window doesn’t do much to reduce the humidity if it’s 95° and 95% rh outside. At least venting the air into the rest of the cabin would allow the ac to remove it. There are plenty of openings inside the head that air could be drawn in from. My preferred method would be to mount a bilge exhaust fan and use hoses to direct the air overboard. But there is almost no space to make that happen even with just 2” ducting.
Has anyone added ventilation to their head?
