Head won't flush
Xhawk101
C-248 C
33 capital yachts
Seacotropic
Looking for help with head that wont flush any water ...dries bowl but no water in any suggestions
Sounds as if you may have lost your prime. If so, easy fix. I am guessing with a 2009 you have the Headmate style head. If so, you will have a single hose which runs from back of pump to head. Disconnect this hose from backside of head and twist so opening is facing up. Fill this tube with water, make sure pump lever is in vertical position (I think, not on boat to verify) and slowly start pumping. This should prime your system, it may take a couple of fills to fully prime.
Ah hah make s sense probably shouldn't pump head when on lift out of the water. ...that likely caused it
