Help finding a couple items on my 2020 R27
F
Fourty
Just watched the Power Management pitch - helpful, thanks.
Ours is a 2020 R27 and I have several questions
Power management Q&A said you are installing galvanic isolators on newer models - how do I tell if mine came with one installed?
I can't find my inverter - can you give me a hint where to start looking?
Thank you - loving the boat and trying to become more knowledgable about the o/b systems.
jz
On the 2018 it is behind the panel where the breakers are located. Tucked in real tight. Have to remove panel for access. Remember it does have a reset button on it if you ever have trouble with the inverter.
There is a on/off switch for the inverter. Mine, R-23, is in the port side cockpit storage. Looks just like one of your battery switches in the cave. Unless the GFI trips on the inverter you should have to access it.
Thanks - I know which the remote switch is and how to use it, but I don't know where my inverter is, and I don't know which one it is? The owners manual that came with the boat says the brand is Kisae - and then lists two types - true sine wave and modified sine wave. After reading about these, I hope (and sort of think) that it is one of the True sine wave versions - but if that is the case - is it the 1000 or 2000 SW1210 or SW1220? I am trying to make better sense out of the solar system (first I have owned) and how it all works and how the parts interact. Not knowing which part I have is frustrating. With the other "generic" parts where I have the factory supplied manual but it is for multiple versions (Garmin, fridge, AC, charger, etc) I just crawled around the boat - found the item and then I knew. Still looking for the inverter. Matty said on an earlier R27 version it was tucked up behind the breakers - so next time on the boat with spare time am going to poke around there and see what I can find.
