Jim and Jackie
- Nov 17, 2016
- C-288 C
- FMLT2930C010
- Chessie
Our R29 has the macerator option for the holding tank. It looks like all you have to do to turn it on is flip the rocker switch on the DC Panel to on. If it is inadvertently turned on and the thru hull is closed you could get a bilge of “black” water. Am I missing something? Has anyone else worried about this? Or are there solutions?
On my sailboat there are several steps before the macerator can be turned on. Rather than rocker switches the panel has circuit breakers and there is a cover over the macerator switch, which it makes it hard to inadvertently turn it on. There are also a second on/off switch on the holding tank and a “Y” valve that needs to be switched from the deck pump-out fitting to the macerator.
Jim Demerest
R 29 Chessie
Jim Demerest
R 29 Chessie
