Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
Seaward Hot water tank model S-600. Drain valve has developed a slight leak, I have opened and closed the valve hoping to reset the seal to no avail. Replacement valve is available online for a few $$ however it is plastic. I would rather replace it with a brass valve if possible. The specs only state it is a 3/4"valve, no info on thread size. I have not attempted to remove the valve until I have a replacement on hand. Has anyone had to replace this valve and what did you use?
My other option is to remove the valve and see what I can find at a local plumbing supplier.
