Hot water tank drain
mddogpilot
R-29 CB
FMLT2934E818
Bon Courage
Where is the drain for the hot water tank on a 2018 RT29CB? Photo would be appreciated.
Assuming it's same as C30 (seems like it is IIRC) then it's a bronze colored valve with a black knob on the end and an open nozzle pointing down, located on the lower right side of the water heater. Turn the black knob to open (and catch the water outflow somehow and funnel into the bilge so it doesn't go all over plywood under if, if that's how it's mounted ...)
I can’t find the water heater
I have an R31 but I seem to remember seeing a r29 during my factory tour. Pretty sure the water heater is mounted under the helm seat. Remove the forward panel in the cave to access it.
Thank you. I’ll check tomorrow
