How to attach teak accessories to boat interior panels
WildRose
C-30 S
FMLT2918E323
Wild Rose 2
Any options other than drilling into fiberglass interior to mount teak accesories?
I wish there were. So far I’ve drilled for book/chart racks and towel hooks. I drilled small pilot holes and used small stainless screws and a hand screwdriver
3M Heavy Duty double back tape. You will have to remove the teak oil from where you wish to apply the tape. I mounted a teak book rack in my R23 on the wood panel wall. It's not coming off. I also mounted my fire extinguishers with this tape, as well as a tide/time clock, Barometer, C0 detectors, smoke alarms. I will not drill a hole unless I really really have to.
https://www.homedepot.com/p/3M-Scotch-1 ... /203405976
I have used 3M 5200 glue. It's what Andrew suggested to us and has worked well. The tape sounds interesting too and would be less permanent.
I agree, don’t screw when you can glue.
Thanks for the recommendations!
we put up hooks for night clothes with Command Strips. So far, so good.
