tugnnaweigh
- Feb 20, 2014
- C-288 C
- Slippn Inn
Hydraulicjump":34en6s3x said:I learn so much from this site. Sometimes I learn too much (meaning I start worrying about stuff that I shouldn't worry too much about). This may be one of them.
I have removed my prop once because I dinged it. I am hopeful I will never remove it again, but I have the gear puller and wrench to do it. Should I be checking propellor shaft runout frequently? I presume that runout should be checked if you think you might have bent the shaft. Right? Or is this something that changes without hitting something?
Thanks. I am dreading adding one more thing to my "stuff to worry about" list, which is approaching Avogadro's number (inside joke for science and engineering geeks).
Jeff
All true if by "runout" you mean as in shop runout, i.e. bent shaft. However, with the boat on a trailer, using a dial indicator to check functional runout and bearing clearance is a way of checking the overall health of the shaft/bearing/coupling assembly. Worn shaft bearings can be the root cause of presistent packing leaks and/or perceived coupling issues. But worn bearings usually indicate something else is wrong(unless they are really old).SGIDAVE":6w25enzf said:Hello Jeff,
You DO NOT need to check prop shaft run out routinely.
You are correct that you might want to check for runout IF you think the shaft might be bent.
Shaft runout will not change in the absence of a LARGE causative factor....like you had a prop strike of heroic proportion....
...If your drivetrain vibrates, fix the prop. If the vibration persists, check the propshaft ALIGNMENT (with the boat IN THE WATER). Forget about prop shaft runout unless you have had a MAJOR PROP STRIKE of Avogadro's proportion :lol: ...like so bad it SHREADED the prop...
