OdyseaII
- Mar 11, 2022
- R-31 CB
- FMLT31081819
- Odysea II
I am trying to add an antenna to the mast on my R31 CB and am having a bit of trouble removing the inside wood access panel that is below where the cables go through the cabin top.
I have removed the screws in the panel but the panel will still not come out. Before I started removing other parts of the boat I thought I would ask for some direction.
It look like the next step is to remove the ceiling strips forward of the panel. Is this correct.
Also can you confirm the square bit driver needed for these smaller screws? Is it #0?
Thank you,
Keith
Thank you,
Keith
