Capt’nKarl
- Feb 22, 2013
- C-242 C
- FMLT2330I718
- Non-Fluid Motion Model
- Previous R-21EC
- DRAGONFLY
Each time I’d fill our fresh water tank no water would come out the vent tube. Not a big deal but I wanted to make sure the vent was open. The tank would fill and overflow but nothing came out the vent. Here’s what I did. I bought a regular rubber plunger suction cup, removed the handle and drilled a 1-2 mm hole in the rubber cup where the wooden rod screwed in. The hole I drilled was just the size of the compressed air attachment used to spray off dust and such. With the water tank empty and all the faucets closed I opened the fresh water fill and placed a small piece of tissue paper under the cap but over the fill hole. I did this so I could visualize any movement of the tissue when pressure was applied. Once all this was done and the air compressor tank full I placed the rubber cup over the vent opening, placed the spray attachment so the air would be forced into the hole and pressed the lever. Air was forced through the vent opening and I immediately heard a slight pop and saw the tissue paper flutter. I repeated this process a couple of times then filled the water tank and Voila water came out the vent. Pictures of the apparatus in my album. I feel victorious!
