Mastercraft
- Dec 4, 2020
- R-29 S
Here is a tip on how to unplug your head sink. I have a 2017 R29 with the blue glass sink bowl. It would not drain at all since it was plugged up with slime. I unscrewed the chrome drain stopper. I tried to pick the slime out with wire or needle nose pliers. No success. Solution was to fill sink half full of water. Take a 50 oz plastic mouthwash bottle that had a 1" diameter opening at top. Use the bottle upside down to squirt air and water into drain. Instantly, the drain was cleaned out. Any large disposable bottle that you can easily squeeze a lot of air & water out fast, will work.
