tkaustin
- Mar 11, 2014
- C-26
- 2501B010
- coming soon to a stern
This is my first year with an R-25 SC.
I've noticed puddles of water consistently in two isolated sections of the hull, which don't drain to the bilge pump area. They are at the stern, one on each side. On the port side, it is the compartment where the stern thruster resides. Starboard, it's the corresponding area, and appears to have the sonar transducer in it.
These spend their summer with several inches of water in them. Now as winter approaches, I have sucked them dry, but I'm wondering why they retain water in the first place. It seems there ought to be an opening so any water that appears there will drain to the bilge for the pump to expel. Is something wrong there?
The next question is about the forward bilge pump. Can it be seen? the only bilge pump I can see is the one in the rear, under the prop shaft. That one I can easily dump anti-freeze into to ensure it's ready for winter. How would one dump anti-freeze into the forward bilge pump?
Thanks, all.
Thanks, all.
