Eric R
- Jun 16, 2017
- R-21 EC
- Why Knot?
I had a little bit of steering fluid seeping from the cap. Not much, just looked wet around the cap. I’ve cleaned it off before, but decided to reseat the cap today and check the level. I almost instantly regretted it once I loosened the cap and fluid came pouring out. I tightened it back up right away but I’m concerned about the fluid loss. It wasn’t a ton, but enough that I had to wipe down the pump, underneath it and the floor. If I were to guess, maybe a tablespoon or so?
When I removed the cap again (ready with rags this time) no more came out and the fluid level seemed to be right at or just below the bottom of the threads for the cap. I turned the wheel lock to lock and it didn’t push any more fluid out and it seemed to stay at the same level.
Thoughts? I’m concerned about why it would have come pouring out like that and if I have to worry about being low now or having air in the system or anything. Definitely wanted to ask and see if there was anything I needed to do before attempting to go out and find out the hard way I have a steering issue! 😀
Thanks.
Thanks.
