BaseCampAnne
- May 24, 2009
- C-288 C
- FMLT2916B313
- Non-Fluid Motion Model
- Eddyline Skylark, Mariner Coaster (kayaks)
- Cascadia
The directions, including socket sizes, appear so useful for changing out the R25SC Yanmar impeller that I wonder if anyone might have experience on the Volvo D4 engine?
I am hoping to carry tools and parts for some potential "issues" and the impeller is one of those. Since I am not needing to change out the impeller yet, I was wondering if anyone has done it and has notes?
My second question is how others close off the bilge pump valve since we don't have a place near the engine to use plastic ties as I did on the R 25.
If a safety check is done, I believe that someone has to crawl under the table area and I do not want to have to empty the "guest" sleeping area in the lower level to access the area to lock it off.
Is there an easily accessible way for the valve to be closed/opened?
Is there some plastic cover I might use on the breaker panel to lock the breaker off with?
Thank you in advance!
