Inflatable Bottom Protection / Paint
GaylesFaerie
FMLT2701D112
Gayles Faerie
I have a new Newport Vessels inflatable that I'll be keeping in the water at the marina (off the boat). I've never owned an inflatable before. What can be done to mitigate marine growth fouling the bottom over the season. Its in salt water on Long Island Sound (slightly up a small river actually). I'm curious what my options are. Is there bottom paint for inflatables? Do I just haul and scrape on a regular basis? Tow it behind the tug at speed on a regular basis? Installing it on the swim step is not an option this season. Appreciate the input. Gary
I have a hard bottom dingy that I keep on the Chesapeake Bay in the slip with my C24. I have to pull it on the dock and scrape and clean every 3 weeks or so depending on water temperature. I even tried ceramic coating the bottom and that might have helped just a little on the cleanup but not much.
KKRCRACE
I rarely used my dingy. However when I did, this may be an alternative for you, I lashed it to the swim platform. It was not as easy as having davits but it worked quite well. I used two ratchet straps secured at the cleats and crisscrossed them to the center of the stern rail. I replaced the open hook at the long strap end with a brass spring clip. I would clip the strap to the swim step cleat. I would bring the dingy to the swim step as you would with davits, with the bow of the dingy to port. From the swim step I would insert the unsecured end of the port strap through the painter ring and then lay it on top of the dingy. I would then take the starboard strap and make one wrap around the tube that is against the swim step and then under and over the outer tube. Then grab both straps and lift the dingy as you would with davits. temporarily tie to rails to hold it in place. Then one at a time attach ratchet ends to the strap, hook onto stern rail crisscrossed and tighten away. I would then also tie the painter line to the stern rail as a secondary tie, just incase. The tube should lay on the swim step. I went many miles this way and in rough seas on occasion and never had a problem in ten years. This sounds a bit more complicated than it is. I would say it takes about ten minutes to set up. And by the way I used a Torqeedo with the shaft mounted to the stern rail on a bracket I made out of 6" X 5/4" thick treated lumber with the shaft on the swim step side so there was no room taken up in the cockpit.
If you plan on getting davits next season then I would definitely not bottom paint the dingy.
I had 12mil clear vinyl wrap installed on my Zodiac aluminum hull. I have been very happy with the simplicity and durability of this solution.
It is an especially attractive solution if you plan to use Weaver davits and apply your vessel name/hailing port on the bottom of your tender. I had Margaux Marine Graphics design a beautiful set of name/hailing port graphics that match the font on the mothership. They are well protected by the vinyl wrap.
Every few years, you can replace it easily if you want to.
Hope this helps.
Patrick
Forgot to mention that the Newport Vessel is all soft with a V bottom created with an extra air bladder running the length of the keel so no aluminum or fiberglass on this baby. The key point I neglected to mention is that this boat will be deflated each winter for storage so I'm concerned about paint staying on the dink where it belongs.
I'm suspicious of the West Marine paint with no mention of it ability to stay on a fungible surface. Vinyl sounds brilliant for a dink but not this one. Good suggestion KnotFlying but we spend a lot of time on the boat at the marina (great views of the river in both directions) and don't want the dink in the way. So like many boaters here we'll keep the dink at the dinghy dock ready for fun up and down the river to visit the marinas, restaurants, and brewery.
For those in a similar situation I just found an inflatable specific paint at:
https://www.totalboat.com/product/inflatable-bottom-paint/
The key feature which I hope proves to be more than marketing jargon is:
"Durable, flexible coating won’t crack or flake off when inflatable boats are deflated and rolled up"
Thanks all for the input! Gary
