Innovative Lighting Courtesy Lights (Amber)
DenverReds
C-26
FMLR2513H516
DenverReds
Hello,
I have a 2017 25SC. Three of the trailer lights are burned out/corroded. I searched the forum and found reference to Innovative Lights on Amazon as a replacement source. Unfortunately, I only see white or blue courtesy lights available on Amazon. These available lights have a distinctly different look (stainless surround) than my factory lights. Has anyone sourced the original amber lights from anywhere? I see from the forum that there’s a trick to getting to the screws to replace these lights - which is helpful to know. I’ll order a few extra in case I break the housing getting replacement lights installed. Where can I source the original amber lights?
I have the same problem and would appreciate help finding replacement courtesy lights.
One of the lights on my transom smoldered over the weekend and luckily blew a the breaker as it melted the light.
Looking on line I found a Hella part number 980855251 that is amber but as mentioned it has a stainless case and I cannot seem to find anyone selling them. Also as stated this is a totally different look and if I replace one I will likely want to replace them all which at an estimated cost of $35/each is a pricy.
I would also like to know the trick to remove the plastic clip. I dug out the ones on the burned out light and they broke, which is not a big problem but may want to keep some of the others when and if I remove them.
Thank you for any update.
I wasn't able to save the black plastic clips when I had to replace mine
Also, when I ordered a replacement from RT, back when their parts department was opened, the clips weren't included and I had to make another order. Not sure if you order directly from Hella if they will come with them or not.
Another has since burnt out and I'll probably go replace them all with something else over the winter. For such a name brand they don't seem very reliable.
