Subject: Installed my Tri-Lens radar reflector today
When boat cruising in the fog the radar and AIS technology can be of use for seeing others.... but can they see you ? If you have a Garmin AIS 600/800 that receives as well as transmits your boat's info, that is good..... In addition a decent radar reflector is good insurance as well. I installed my Tri-Lens radar reflector today for added safety. 🙂
I was hoping the installation could make use of the 3 holes on the upper mast's plate, but alas, they were too far apart. I had to get my trusty portable electric drill to drill out three 1/8" pilot holes in the SS plate and then opened them up to meet the bolt 1/4" diameters I planned to use.
The Tri-Lens reflector is a weighty item and there have been reports when they fall off causing much damage to the boat. After securing the lens with three good sized bolts, locking washer and nut, I also secured the whole lens with a sturdy white zip tie to the mast-proper just as a safety and redundant attachment. I placed the lens on the starboard side of the mast as the mast when lowered goes to port.
In addition, I positioned the Tri-Lens's three lobes such that if the Tri-Lens were to loosen from its bolted base and start to twist the Mast pole would obstruct this and not allow the Tri-Lens to twist/turn any more than a fraction of a 360º turn. The Tri-Lens screws onto it base with at least a dozen 360º turns.
See here -> https://www.icloud.com/sharedalbum/#B1AG3KxPyGojIlZ
