Inverter Location on an R23?
cruz-in
18 foot cubby cabing Catboat
Auuumn Wind
Good Morning Team,
I am getting ready to install an inverter on our R23.
For those of you who have the factory installed inverter, where did RT install it?
Dan
Thanks for the super quick reply.
Is it behind the breaker panel and accessable thru the port side locker? When you stick your head in the port side locker and look toward the front of the locker, is it lacated on the front wall of the locker (the one behind the electrical panel) ?
Or is it accessed by removing the breaker panel?
Thanks again
Dan
On my 2021 R-23, it is to the right of the battery switches, on the back side of the power panel.
Thanks!
Is it accessed by removing the power panel?
Or through the cockpit floor locker in the cockpit?
Thanks tons, I am just confused by the "behind the power panel.
Any help clarifying would be most helpful
You all are the best!
It's sandwiched between the wall the breaker panel is mounted to and the forward wall of the port side cockpit locker. It is not really accessible without a bunch of disassembly. If you're installing a new inverter you might need to look for an alternate location.
Under the breaker panel is a removable strip about 3" wide. Removing that allows access to the GFI on the inverter with a screwdriver, or a child sized hand. Otherwise it's buried in there.
Thanks!
I understand now. Does sound crammed in there.
I am considering placing it on cockpit side of the hull liner hull behind the electrical planel.
Thanks again for the clear response.
This is a great, helpful forum.
