max from alaska
- Jul 13, 2020
- C-28
- FMLT2726K314
- Clementine
I have a 2014 R27. When the inverter is run off the house batteries while at anchor (engine not running), I attempt to run the microwave. The voltage before running the microwave is about 13V. When the microwave is run to heat a cup of water or similar, the battery voltage drops to 12.5V immediately, and within about 10 seconds the inverter trips off (the inverter remote monitor shows zero input battery voltage even thought the battery voltage is at 12.5V). Is the inverter defective in that it cuts off at 12.5V (whereas the unit is rated at low voltage cutoff at 10.5V). The unit is a Promariner 1500W model 5150.
During this event the battery voltage never drops below 12.1V during the draw, recovering to about 12.7V afterwards. I assume the problem isn’t a bad battery. Correct?
