inverter
ftornabe
R-25 (Outboard)
FMLT2535A121
Sea Wolf
Hello,
My boat is a 2021 R25 and the inverter doesn't seem to be working. The panel will only work when connected to shore power. But when disconnected with house batteries on and flip the inverter switch on, nothing on the panel is charged (stovetop, outlets, AC/heat,...). There is a switch next to the batteries that says 'inverter' which is in ON position.
Any ideas?
Thanks!!
If the battery switch for inverter is on in the port cockpit hatch, and ac panel inverter switch is on(green light on), then there should be a separate inverter on/off remote switch next to the panel. You will need to turn on and verify green light on and ac panel shows ac power. Hope this helps. I’ve attached a picture of what my remote on/off switch looks like.
I think there should be a large fuse associated with the Inverter and close to the switch near your batteries. Check to make sure it is not blown. GF
The inline breaker near the inventer switch has a red disconnect button and a black or yellow lever that resets by moving it upward. Push the red and then reset....hope that's it...
I tried pushing the red button and resetting the breaker, no help. I don't see a fuse near the breaker. Perhaps it's behind the panel. When I flip inverter switch on the panel there's no lights on the panel. So its not getting electric meanwhile the panel is electrified when shore power is on. Got to be a fuse or something not wired right. I don't recall the inverter ever worked.
My inverter has a reset button on it. Small button on the end of the inverter next to output plug. Check to see if yours has one.
