Is it possible to put the Ranger 29 on a lift?
Swansboro Dave
C-288 C
FMLT2917K910
And if so....what capacity lift would you recommend. I have a 16,000 lift. Is that enough?
Sure it is. As long as the boat is supported with beams that run all the way forward and back spread out evenly where we put stiffening in the hull. Make sure your lift has the clearance to accommodate the keel. This also depends on which model 29 you are considering as the keel depths are slightly changed. Feel free to contact us directly at our main office number and we can assist with any other questions. (253)839-5213.
Thank you,
Ours is about 13,000 loaded so the numbers should work.
How about a R-31CB?
Planning bunks longer than sling points.
What is the weight wet?
I am estimating about 14000 lbs.
Thank you Andrew for that quick and helpful response.
While my bunks appear they would span the front are rear sling lift points.....
They certainly would not (as currently configured) span fully from stem to stern...
The existing cradle/bunks are however located aftward (i.e. motor would be sitting just about over rear cradle beam.
If any one has any drawings, dimensions, and/or measurements for proper bunk configuration...
That would be most helpful.
Thanks again.
