(1) Is your boat using shore power with a battery charger charging the batteries.
Yes, boat is connected to shore power with the ProMariner Charger as equipped from the factory (2) When you leave the boat what battery switches are left on if any? What breakers are left on for equipment to run.
I was taught to leave just the House switch on and turn off the Engine/Thruster/Generator switches. I forgot to take a photo but I will next time I get to the boat for breakers left on... I think refrigerator is biggest power drain.(3) When you are running the engine what is the voltage readings of each battery bank?
There are 3 battery banks. I think they were reading around 12.6-12.7 on the Blue Sea DC VOLTS panel (photo below when plugged in to shore power reading about 13.7). However, on the Engine display (and Garmin), it would alternate between 12.4 and 12.6 at idle and drop to 12.1-12.3 when at cruise/WOT.
Engine running, engine battery should be at or above 13V and increasing as you cruise.
It drops below 12.6V and "LOW VOLTAGE WARNING" pops up on the Garmin and the Volvo display. It did that for a while prior to replacing all 6 batteries and I hadn't seen the Low Voltage Warning for a few outings since replacing all 6 batteries.
Once the engine battery voltage gets to 13V for 90 seconds the ACR's should close and parallel each battery bank as one. If either battery bank house or thruster is less than 9.5 V the ARC will not close and that battery bank will not charge from the engine. Using the cross over/parallel switch House to engine (on position) will "excite the battery" reset, and the relay will now close and the engine battery and house will be paralleled. Turn the cross over switch back to off when this happens. The thruster battery if it is below 9.5V will need a way to get a parallel circuit connecting house or engine battery "exciting the thruster battery". After you have done these steps you need to confirm that your ACR's are closed and all batteries are being charged. The ACR's green LED light should be on. If it is not you may have to troubleshoot the ACR's. Most common failure is the yellow ground lead is not attached properly to the correct ground terminal on the ACR.
If I'm reading the above correctly, one or more of the batteries was below the 9.5V threshold and not charging? After reading the above, I went out on the boat and cruised around for a bit with parallel switch ON which seemed to raise the system voltage (shown on Volvo and Garmin screens) up a bit to 12.3-12.4 from the 12.1 I was seeing before. If I understand correctly, this should have raised whichever battery back above the 9.5V threshold evidenced by both ACRs showing GREEN after plugging back into shore power?
What conditions were involved when the house battery discharged enough to cause the auto pilot to go into reset loosing its memory.
I'm wondering if someone who was working on the boat disconnected shore power for some reason over the past two weeks or perhaps we had a power outage? Would the house battery being low show up on the Volvo and Garmin screens as "Low system voltage"? Was the house battery left on without a charger? When the house battery is left on there are other circuits that are running the biggest culprit for amp draw is the refrigerator, inverter, auto pilot if on along with the chart plotter all are using available amp hr's. When not on board and house battery is left on the shore power battery charger should be on.
House battery switch is always ON as boat lives in a slip connected to shore power except for when we are out for usually 2-4 hours at a time. It's possible the shore power was disconnected or maybe there was a power outage that allowed batteries to run down even though I thought it was all connected?
The CO detector draws very little. The battery charger 20 amp or higher should be able to maintain several 12V circuits being on and still maintain the batteries. I have left the boat without charging it for over a month without pulling any 24/7 fuses and never discharged a battery less then a couple of tenths of a volt. Although I do recommend removing the fuses if the boat in not in the water and in storage. I do not recommend removing them if it is in the water and may be used from time to time (including the CO detector fuse).
I disconnected the fuses to stop the beeping while I wait for 10 year battery powered units to arrive. I'll be installing them unless I get feedback on the other thread that the units I bought shouldn't be used!
First check battery condition, battery terminal connections, load test each battery. Just because it is newer does't mean it's good. New batteries fail. Always start with the source (batteries) Troubleshooting. All Batteries fully charged and load tested (good)
So, I'm a neophyte at this and don't know how to do that. I YouTubed and found this (https://www.youtube.com/watch?v=yp1LSWLKwuI). Can you recommend a load tester? Would I be able to load test the batteries on the boat without disconnecting or do I need to take each battery out to load test separately? The video talks about battery temperature... should I run the boat for a bit or do something to warm up batteries before load testing? Sorry for all the newbie questions!
Next check amperage draw at battery. All battery switches off check each battery draw should be around .5V to 1 V depending on what 24/7 circuits are used on the battery bank. (good)
Same questions as above... Can I test this while everything is hooked up or do I need to disconnect each battery to test? As above, do you have a recommended tool for doing this? (I'll look up usage and testing procedures unless you can point me to some resources you know off the top of your head!)
ACR's, engine, thruster and house batteries at 12.75 V or more green light on, less than 12.75 green light off.
So, if green lights were ON for both ACRs on shore power... good? I guess I'll find out next time I get to the boat whether all the batteries charged back up or if there's a problem with a battery and I still don't get system voltage over 13V while underway?
Engine running, engine battery at 13V, house and thrust are( good ) ACR's close green lights are on all battery voltages are the same. Green light not on trouble shoot ACR's
I will check this next time... but if system voltage doesn't get up past 12.1-12.6 with engine running, then what?
Shore power/generator. 120V charging. Charger on, charger output to each battery, when one battery reaches 13V and the other batteries are above 9.5 Volts ACRs close and all batteries should read the same, green light on. ( unless you have ACR's disabled when using Battery charger) If disabled you should still read all batteries above 12.7 Volts and climbing to between 14.3V to 14.7 V. if you are not getting readings this high when shore power is on and battery charger is on ,possibly a bad charger.
So ACRs were both GREEN and batteries on the BLUE SEA panel were showing about 13.7V so good?
Troubleshooting: Start from the source and work out to find the issue.
Thanks again for the above and hopefully your responses can help other novices like myself who don't quite understand all this electrical jargon!
