Rocky Lou
- Aug 2, 2019
- C-302 C
- Sea Suite
One of the ways to avoid future errors is to review what went wrong. I've been a big fan of the Blue Angels ever since John 'Gucci' Foley spoke at my company and talked about how they achieve near perfection in flying. When John is asked if flying at 1000mph at another aircraft with 3 ft. of separation is dangerous, he replies, 'no, but, it's inherently unforgiving'. He told us that the Blue Angels have a rigorous review process that is the key to staying safe.
So here we go, this is one of two of my major screw ups that has happened in the last 40 years or so of boating:
2. Kiase Inverter: dead, I'm now on inverter #3, the first died a natural death. The only bright side is that I get good discounts, more each time, from Kiase and I've learned to do it myself. Before #2 died, it made a few attempt to revive itself, then flatlined.
3. Stern Thruster: this was, by far, the big ticket item since I was stuck with moving from Gen. 1 to Gen. 2...I've written volumes on the topic and hope to stop thinking about how bad that was: https://www.tugnuts.com/threads/anyone-replace-lewmar-stern-thruster-lately.22672/#post-155812. The 'waterproof' IP casing had cracked and water killed the thruster. The Gen. 2 migration requires changing just about everything in the bow/thruster system.
4. Generator: never one to be overlooked, the Westerbeke shot off a variety of error codes: my mechanic first changed the starter motor that was badly corroded; I changed my oil, that looked like honey, and filter. Then the butterfly froze and the engine speed indicator came on. Luckily, my mechanic was able to take the unit off and repair it, rather than replacing another $2K part. Because the generator is in such a bad place, basically the bilge, it always has some salt water exposure and I put loads of CorrosionX on it...next I'm painting it with a primer than turns rust into a paintable surface.
5. Solar Controller: I'm really not sure it this was caused by bilge flooding or not since mine is located high up in the starboard lazarette, but, I replaced the controller since it was not working.
Well, now I can get back to spring cleaning and the 'fun' stuff. I'm just hoping that the next major screw up will again be in forty years, so I won't likely be around to see it;-)
- Last September, BlueFin Tuna fishing was on here in the SF Bay Area. I planned to take a couple 'young guys' along since hauling in these giant fish is tough duty for septuagenarians. The night before we talked about live bait without any conclusion, but, in the 0dark30 hour the guys showed up with some lovely live mackerel. FM owners will know that you need to swap out the grill and set up the live well, which I proceeded to do half awake and not planning to do so.
- As I was about 3 miles offshore heading for the HMB buoy that's roughly 20 miles out, I asked the guys to come forward as I was having trouble keeping the bow down. I kept using trim tabs and other methods, without success to right my keel. Not sure at what point I realized that something was seriously wrong and opened the bilge area. Yup, it was 2-3 ft. deep there and the fwd and aft bilge pumps were ineffective, one was dead and the other was on life support. Of course, I turned off the live well, spun and headed back with the weak bilge pump barely helping. Back at the dock, I realized the 3 position bilge alarm was OFF (not happy with the design) but I'm still to blame. As you may now have guessed what happened, when you pull the grill, you need to plug the hole that the cord runs through or the live well pump goes straight into the bilge.
- So what got damaged and how much to repair? TLDR: very expensive but would have been three times as much if I didn't find a moonlighting mechanic and work along side him. Total cost: about $7k vs. $20k+ if I dropped it off.
