Jabsco Lite Flush Toilet
kelpline
FMLC2813B111
the Corinthian
Our Cutwater 28 (2012) came with a Jabsco Lite Flush Toilet, which the crew plugged on our first trip home. An old shop vac was sacrificed to empty it, and still it would not flush out. In Canada a new toilet is C$1250, and the flush pump part is $650, "there are no repairable parts in the flush pump mechanism" said the Jabsco manual.
When I disassembled the toilet, a broken Gates powerbelt appeared as cause of malfunction. An internet search found GATES GT3 270 3MGT18754218DS available from beeline.uk, but they had a minimum order of 10 belts. I ordered on Thursday, on Saturday I got a call from a import broker, and on Monday morning a knock on the door with delivery. So I am keeping 2 belts for spares. If you see "the Corinthian" in the Salish Sea, Desolation Sound or the Broughtons this summer, and want to fix your own toilet, you can have a belt for $20.
We had the same problem with our Jabsco Lite on our R27. I found a "rebuild kit" at west marine that had a single belt and metal sprockets. I couldn't replace the sprocket on the shaft that is in the toilet, the motor sprocket was easily replaced. The shaft for the flushing mechanism had siezed also. I managed to get it turning and liberally lubed it. So far it's working. If it fails again, I plan to replace the toilet and go fresh water flush as many others here have done.
