Jfrano
- Aug 12, 2018
- R-29 CB
- June Sea
Have a RT29. How does one remove the cartridge to clean, access is soooo tight?
I was blowing the 7.5 amp fuse but could still manually start pump. Eventually I was unable to manually start. I would have to reset bulb at the helm. I cleared out water and used wet vac in the bilge area. Now it’s running fine. Still want to pull cartridge to see if there any more Debris.
