MechGuy
- Feb 19, 2024
- C-302 C
- Sapphire
I noticed something that sounded like a small electrical motor running in my engine compartment and realized it was the aft bilge pump. There was no water in the bilge so I found this strange. I found that I could shut it off by flipping the dc breaker on then back off. I threw some water in the aft bilge to check its operation after I was able to get it shut off and the bilge pump pumped it out and shut off like it should. Went down to the boat today and the pump is running again for no apparent reason. I pulled the cartridge out and checked for debris but it didn’t look too bad. I cleaned around the float sensor which was a bit dirty and pumped the bilge dry. We’ll see if anything I did helps. Anyone experience this issue with their Johnson pump?
My inboard shaft packing is dripping more than it should, a couple drips a minute while not running, so most likely it runs the pump when I’m gone from the boat from time to time. Apparently it doesn’t shut off sometimes.
