nzfisher
- Jan 26, 2009
- R-25 SC
- Swims with Tuna
Probably like most of the other R25 owners out there (probably other models as well) my engine mounts are deteriorating mostly on the starboard side due to cleaning the sea filter regularly. Of course when you close the raw inlet valve and open the sea strainer, raw water pours all over your engine mount(s). I have found that after you close the raw water valve, if you turn on the raw water pump hose and spray out some water it partially drains the cup- no overflow if you do this. Too bad I didn’t start doing this earlier. If there ever was a place to use SS it would be the motor mounts. I dread touching them at this point for fear of finding failed bolts, detached mounts and over all decay. On the replacement list I guess. I would love to find some SS replacements if anyone has dealt with this issue.
