Gin
- Dec 12, 2012
- R-31 S
- Echo II (2019)
With the unstable NW weather of late, I feared we might lose power at our boathouse, which is 60 miles from home. That didn’t happen, but if it had, the house batteries would quickly have been run down by the space heater and a dehumidifier I had running on board. Especially if, as has been true the last few days, roads were closed or treacherous to travel so that I couldn’t get to the boathouse to shut them off.
After reviewing the Kisae owner’s manual, I decided that at times like these, I’d be better off with the In0 setting, rather than the In1. The difference is that with In0, if shore power goes off, the inverter does not continue to provide power to AC loads. The In1 setting, on the other hand, provides “backup” power to AC loads through the inverter if shore power goes off. The result, of course, is that , is that the house batteries get drained, and quickly so with a load like a space heater.
I ran into two issues today when I tried to change the Kisae setting. First, the change wouldn’t take. Each time, after I set it to In0 and then scrolled through and checked the setting, it had gone back to In1. I think that may be due to a user error on my end. I just reread the manual and it looks like I need to change the setting and hold down the “select” button for a full 5 seconds for it to take. I will try that on my next trip.
The other issue is that my unit had settings that the manual doesn’t describe. After I scroll through In0, In1, and In2, it goes on to In3 and In4, neither of which are documented in the manual. I searched on Kisae’s website and can’t find anything about them.
Does anyone know what In3 and In4 are? I may try calling Kisae to ask. But until then, if anyone has run into this and has it figured out, please post what those settings are for.
Thanks!
Gini
Thanks!
Gini
