Scottfree
- Mar 29, 2013
- C-288 C
- Scottfree
On our way back from Gorge Harbour we got to play in some bigger waves. The water was breaking well over the bow and hitting the windows. I have them well coated with Rainex which turned out to be a good thing. When I turned on the wipers they float at least a half inch from the glass! Not an issue the Rainex worked well. Upon inspection the arms are the old style aluminum ones used on cars from the 60's and the spring has no tension left. I'm sure ill have to cut them off with a dremel. Is there a modern replacement? The fix when I was a teen was black springs that you put over the arms to increase pressure on the arm. All I can find online is the blades, I need a new improved whole arm assembly.
Any suggestions?
Cheers, Leon
Any suggestions?
Cheers, Leon
