Alpina
- Sep 11, 2020
- C-30 CB
- Alpina
Fortunately I had placed an oil absorbing mat in the bulge under the hydraulic pump for the trim tabs as I had to re-silicone the depth gauge and was drying up the oil from that issue. Saw the hydraulic pump reservoir below full and added hydraulic fluid. Some time later I found a good amount of fluid absorbed by the mat and wondered why. A little research later I learned that the trim tabs have to be fully retracted before adding fluid. Lesson learned but fortunately, not too messy because I happened to have the mat in place.
However, I did notice ATF fluid leaking from the bottom (piston) side of 3 of my 4 actuators. Called Bennett and they owe me a response. Was told there is a lifetime warranty on the hydraulic cylinders. Boat is just a little over two years and old. Am surprised by this as they were as well. Has anyone experienced this so early?
Related, has anyone installed the module from Bennett that auto retracts the tabs? If so, how easy/difficult was it?
Franco
Franco
