Learning the Electrical Side - Tips?
wabislander
R-21 EC
17' wilker
river time
Still in the research phase on which Ranger, but understanding that the more I can understand power management the better I will be (should have paid attention in 8th grade shop... :roll: ). Trying to figure out how I can build up my knowledge starting with not knowing a watt from an amp. Any suggestions or direction (books, on-line courses, etc.) would be greatly appreciated.
Good advice.
Getting a good clamp meter and learn how to use it will help. A killowatt device from Amazon helps too. You need to know the power consumption of whatever devices you're going to use. And you can circuits for good ground, power, etc.
More than once I have had marina people tell me the pedestal is working fine until I plugged my meter in and had them read it. Then they're like "Oh wow, I'll call it in."
Lots of good books out there. I happen to like Nigel Calder's "Boat Owner's Mechanical and Electrical Manual". He has all the formulas in there. You can ramp up on this pretty quickly. For example if you have a coffee pot you want to check for power consumption, look at the UL sticker for the watts. Let's say it's 500 watts. At 120 volts, divide 500 watts by 120 volts, and voila, you now know you consume 4.16 amps for however long it takes to brew coffee. That gets you pretty close. No meter required.
However, I feel its always more accurate to check with an actual meter. If you do get one, look for one that can measure DC amperage. Many don't have that. I use a little Sperry. Lots of better meters out there, but I haven't found the need myself. It's small and fits in my tool bag. My father always said the best tool is the one you have with you when you need it.
-martin
Can someone recommend a specific meter that is handy to have on a Ranger 31 CB?
thanks,
Bruce Moore":3vazudzm said:
Watch the factory's As the Prop Turns: Power Management to get started.
Cheers,
Bruce
I have watched the Power Management "As the Prop Turns". Does anyone know where the power usage spreadsheet from that presentation can be found. I could not find it as an attachment on Tugnuts or the Ranger site?
You'll find the slides and spreadsheet here.
If you go to the As the Prop Turns page on the Ranger Tugs web site you'll find links to any document (slides, Q&A transcripts, and spreadsheets) for each episode.
Cheers,
Bruce
thanks,
This is the clamp meter I have. Not the cheapest you’ll find, but it is very nice quality and small enough to store easily.
https://www.bluesea.com/products/8110/M ... er_-_AC_DC
It can be found for significantly less than than the MSRP of $201.
I will also recommend Nigel Calder's book; make sure to get the latest edition. The electrical basics stay the same but things change a lot in electronic gear over the years.
Also recommend the Blue Seas 8110 clamp meter; not cheap but very useful.
The blue seas is an excellent tool. I happen to use the Sperry DSA540, which is similar .
The internet is a great tool. If you want to learn about batteries, DC current,AC current, amps to watts, watts to amps, converting 12V DC to 120V AC watts/amps there are conversion formulas and calculators available. Many Inverter manufactures have tables for power management. When searching and reading articles, many are opinion based with good factual information. Read them and try to understand the basics. Then use the information to get a better understanding. The more you dig into the information and put it to use the better understanding you will have.
I found a collection of YouTube videos from PYS to be incredibly helpful and understandable. I great way too to wile away the Covid quarantine hours:
YouTube Seminars by Jeff Cote of Pacific Yachts
1 of 12 Batteries Part 1: https://www.youtube.com/watch?v=QZcf_gpbFf4
2 of 12 Batteries Part 2: https://www.youtube.com/watch?v=N5raZtxfCjY
3 of 12 Recharging your batteries: https://www.youtube.com/watch?v=OgsMBe-DFJo
4 of 12 Inverter/Charger: https://www.youtube.com/watch?v=u7BjwmOebfE
5 of 12 Charging Sources: https://www.youtube.com/watch?v=5WZpaWuYsME
6 of 12 Power Sharing and Monitoring: https://www.youtube.com/watch?v=uokjv6gPPEY&t=2024s
7 of 12 Troubleshooting: https://www.youtube.com/watch?v=RqkpH5-9xPY
8 of 12 Wiring Essentials: https://www.youtube.com/watch?v=lk4uuEYfCAQ
9 of 12 Troubleshooting Electronics: https://www.youtube.com/watch?v=Q0PtfTuZKqs
10 of 12 Troubleshooting Chargers and Inverters: https://www.youtube.com/watch?v=hhp0u8K9-lo
11 of 12 Troubleshooting Alternators & External Regulators: https://www.youtube.com/watch?v=IGsFNjRC0mY
There are a lot more videos from PYS on marine electronics as well plus other publishers as well.
HTH,
GF
Thanks for the feedback. Have some of the recommended books on order and the youtube's downloaded for rainy day studying.
I have posted some videos on our you tube channel “Let’s Go Channel Surfing”, about power management specific to the Rt27 outboard that you may find useful.
I’ve also put together a spreadsheet that helps a lot with understanding electrical usage.
Also, anything that Jeff Cote at Pacific Yacht Systems publishes is worth the time to watch.
And above all else... before you modify anything electrical, you should educate yourself on your own needs while on the boat. How you use a boat is most certainly different than somebody else. Having a battery monitor installed so you can see your own usage is paramount in my opinion.
I have a C24 and just watched the charger, inverter video which is above my head. Living in the south when it’s warm, I get the low battery power signal, E1, while running the a/c after 1 1/2 hours. I’m wondering if the inverter is installed properly or is it the incorrect inverter.
I would appreciate any thoughts.
