LED Cabin lights
Rebel
C-248 C
FMLT2565K708
JOHN'S FOLLY (2008)
I believe that sometime back there was a comment about finding LED lights for the lights in the cabin. I do not remember seeing anyone saying that they had found any yet. I have found LED replacements for the G4 10 watt halogen fixtures in the ceiling of my 2008 R-25. Three companies were represented at an RV rally I was at this last weekend. Following is information about two of them.
I purchased from a supplier called TrailerLights (TrailerLights.com). I have looked at his web site and you will need to navigate to the type of fixture you have. I bought 8 ( and replaced only 7 because I damaged one) and found them to be difficult to slip into place. There is a spring clip in the base that will not allow the prongs to enter unless you get them exactly in the space that is widened to accept the prongs. Could not just shove them in, needed to find the right hole. The LEDs are warm while and 140 lumens and draw less than .2 amps according to a meter they salesman had them hooked up thru.
The second supplier is called JIRAH (jirahled.com). They both use a round disc with LEDs on it and two pins attached to the back. On the lights I bought the prongs are attached directly to the back of the disc, parallel to the back. On the ones supplied by this outfit the prongs went straight back from the disc about 1/8th of an inch and then turned parallel with the back of the disc. My reason for saying this is that these may be easier to install but I am afraid that the disc may lay on the light lens. Heating of the lens certainly will not be a problem but they will certainly be more visible.
One thing is for sure, the lights look good and actually increase the light level in the cabin. I believe we will like them. We will be taking John's Folly up to the Columbia River in the morning so will know more soon.
John Turner
Go to Marine Beam. They have what you need and Jeff is very helpful. You need to check your existing bulb base because I discovered that what is on one tug can be different than another even though they may be the same model. Mention Ranger and you also get a discount.
We ordered all of our LED lights through Marine Beam. We had no issues with the fit or the brightness of the lights. We have replaced all of the interior lights as well as the navigation lights. The one thing you will notice with the LED lights is, the head will no longer become a mini sauna with the lights on. The halogen lamps really put off a tremendous amount of heat and with five of them in the head......
David, We are anxiously awaiting the delivery of our 2012 R-29. I too noticed the heat that was generated from the head lights so I would like to go to LED. Do you recall the MarineBeam part numbers for the LED bulbs?
thanks
Jeff and Marie Royle
Newport Beach Ca.
Jeff,
I do not recall the part number however, I Do have the invoice on Karma. I will post it tomorrow.
David
This past week I placed an order for LED lamps to be used in the overhead light at the dinette. I placed this order through Marinebeam. When entering the "coupon code", it was declined. As many of you know, Jeff at Marinebeam had extended a 10% discount to Ranger Tug owners. I contact Jeff via email asking if the discount code was still in effect. He said it had expired but would reinstate it. The new coupon code is simply " ranger ".
The item numbers for the bulbs that I have ordered for Karma are:
Navigation Lights:
44mm Festoon LED FS-44-30B 2
Color = Warm White (behind
Navigation light
bi-colored lenses)
Dimpled Barrel End -
Aqua Signal Type
Overhead Halogen Lights:
G4 LED Bulb SP-G4-10 11
Color = Warm White
10-LED SMD Power Cluster
X-Beam
Overhead Dinette Lights:
T10 15-LED Wedge WG-T10-15 5
Output Color = Warm White
Mini-Tower
We are now 100% LED equiped!
