stwendl
- Aug 11, 2015
- C-28
- FMLT2719J516
- Cataleya
Looking for some info with legal references or someone with authorities answers to the following questions:
The cruising limit for a non resident in WA state is 60 days with one extension of 60 days in any 12 month period if I heard right. Now, does this refer to being in Washington or being on the water in Washington? In case of a trailerable boat where the boat can be taken out of water and stored on land, or for that matter, a non trailerable boat taken out with a lift, one would not be cruising.
I called the department of licensing and while the person was sounding like not knowing everything I was told this applied to being on water only. Further more, if the boat is taken out of the water then the cruising time freezes until the boat gets back into the water. Kinda makes sense. Keeping logs of trips apparently helps to prove staying within those time boundaries.
I would assume that if you come to wa by boat or by transport to spend a week in the water, which is really not long enough to explore the region, then take the boat out to go back to work it would not really be fair to burn a 60 day pass/permit.
So coming back a month later taking the boat back into the water were left off and continuing should be an option.
I have not found any definitive reference to this in any writings on the relevant licensing website or by calling them.
Anyone with info who can clarify this? Wouldn't want to break any rules. Thanks for any references, phone numbers or email addresses of someone who knows.
