Lewmar 1000 wiring at the unit
racurry@unb.ca
R-23 (Sterndrive)
Water Weaver
Hi. I have to replace my Lewmar 1000. Its wiring is AWG 6 or 4 (it is unmarked) and on the boat, the factory has connected this to its battery grade 600 volt FT-1 or AWM I A/B which is a big difference. What is the connector that is used - what do I need to find and buy?
Just replaced mine I used #10 AWG bare crimp butt splices and used heat shrink. I do not like pre-insulated butt splices as you cannot visually verify the crimp. Leave some slack for future replacements and use cable ties to secure.
Additionally, if you are not using ratchet crimpers, I would recommend placing the split in the tool face down in the crimper so you get a more secure crimp. With the connector face up the crimp may not catch both sides of the crimp connector.
Thank you, Brian. I can see the #10 will fit the Lewmar wires, but that doesn't seem large enough for the boat's factory wires?
I replaced the Lewmar on my R23 prior to sale, I'll look at the conductors on my R31 tomorrow and get back to you.
On the 2022 R31 CB, the conductors are#10 AWG, I would use #10 butt splices and adhesive-lined heat shrink. If the conductor from the new windlass is a smaller gauge bend the wire over and when crimped give it the pull test.
Thanks. The factory wires are not small enough for butt connectors, so I left the factory connection intact leaving about 6” of original #10 wire that I then crimped and heat sealed to the new wire of the same gauge. I put a second heat seal then electric tape on the join. Electricians will be cringing but there was no other solution. Overall it not a good design for wiring and placement of the wires which are so close to chain and rode. One of a “few” issues I have with the boat designers.
