lighting question
krispirae
C-248 C
MischiefManaged
Hello! We have a 2008 R25 and just recently our head light, cave light and the light in the galley have stopped working...we changed the bulbs and that didn't help, any suggestions on what it can be? We just had all the batteries changed and I ckd the fuse...thank you
You most likely did this as well but in case not was the breaker switch for these lights on the breaker panel turned to the on position?
Jim F
Besides what Jim suggested you should check the connections. Sounds like something got disconnected or corroded in the circuit.
Make sure you can turn the breaker on and off, I had one that quit even though it was in the on position. I had to disassemble it and fix it.
