On my 2016 C26 I see 2 limber holes under the floor board of the V-berth in the compartment where the shower sump and sonar thru hull are located. One hole allows water to enter the compartment from the direction of the bow and the other allows water to exit the compartment towards the stern. I’m sure the water that flows through the exit hole eventually ends up in the aft bilge, but can’t figure out where the water that enters the compartment from the direction of the bow is coming from. Any suggestions will be appreciated. Thanks.
