location of 2022 R27 OB freshwater tank
Satu-Lagi
Satu Lagi
Hello Ranger Tug Fluid Motion,
I had to replace my leaking hot water tank. I am now trying to prime my freshwater system with no success. I checked the filter at the pump intake, there are no plastic shavings. I am not able to remove the filter from the intake hose to blow into the hose to identify any blockage. As the pump runs, water pulsates out the pump and no steady flow. I am tryin to locate my freshwater tank to see if I can gain access to the top of the tank and check the intake tube to see if it resting/stuck to the bottom of the tank and NOT allowing suction ? or the tanks has sagged ? please pass along the location and instructions to remove any time in the way to access the water tank top. Thank you
Access to the freshwater tank is through the mid-berth on the port side. Remove the panels near the floor along the port side to gain access.
