Location of propane sensor? R27 ob
berger
FMLT27311819
Seawind
I have a 2019 R27 OB...where is the propane sensor located? Alarm randomly goes off even with propane bottle shut off. Problem may be in faulty sensor since manufacturer says sensor needs periodic replacement. Could not find information on this in any Ranger materials.
I had an inboard, but I suspect the sensor is in the same spot. It is most likely below the oven near the rear of the storage under the oven. I had to replace mine. I cut the wires and reconnected the new one since trying to snake it back to the switch unit would have been a pain.
Thanks for the information, but I could not locate the propane sensor in the cabinet below the oven....Factory folks are looking where it is located....will update once it is found by them, I hate to think I need to pull the over to get at the senor...probably not integrated into the control unit...have a neighbor with a 29 Cutwater (2019) with the same control unit and his sensor is in the cabinet bit is below the oven....again on my Ranger 27 OB (2019) the propane sensor is not located below the oven....
Ahoy all, I found the propane sensor on a 2019 R27. It is located behind the meter face mounted on the shelf. You have to remove the Force10 stove/oven to get access to the sensor. After you remove the stove, it is easy to see.
Bumping reply delayed in moderation queue.
