Looking for replacement mast light - R21EC
Boris the Tug
C-24 C SE
I bought my R21-EC used last year and the sternlight (all-round? Masthead?) was missing. I’m not sure of the name of the light but it’s the one on the top of my mast. The owners gave me a replacement part and I got motivated to install it today but I realized there is no way this thing fits with the hardware they gave me. I’m thinking it’s not even the right part or they probably would have already fixed it.
Can someone please suggest a replacement part? The weather right now is in that sweet spot for tug tinkering.
Aqua signal 2nm.
Concur guys: I replaced mine a couple of years ago with that particular model and brand. Fitted perfectly. Regards
I had to replace mine and bought it directly from Ranger.
It does however look like the one in the Amazon link.
If you anchor out a lot, replace the bulb with an led one.
Great thanks for the assurance. I ordered it from Amazon and got the LED replacement. Price was right...finally something I don't have to break open my piggy bank for.
Did you have to cut the wire connections off to remove the base of your old light? I can't remove the base because the wire connections won't fit through the tiny hole on the bottom. I don't have much play in the wires but probably enough to cut and replace the connections once. Wish I didn't have too though. Any thoughts?
The mast light plastic cover will twist off. You may have to push it down a smidge but it should come off fairly easily. Once the cover is removed the LED light should fit in the socket.
Cheers
Karl
