Loose Bow Rail
bails023
R-21 EC
FMLC2815H314
Cutwater 28
First & Last
I had a mishap that slightly bent the port bow rail on my 2014 C-28. The aft two rail mounts were loosened by the blow. No other damage. A shop said the bend is minor and easy to straighten however, tightening the aft two mounts may be a different story. The aft two rail mounts are just slightly "loose", not pulled out of the fiberglass. Is there a way to access the two aft port side bow rail mounting hardware beneath the deck?
You can access the port bow rail bolts thru the v-berth area. The aft bolt is located in the breakfast nook area and the one fwd. of that is accessible by removing the lower ceiling panel along the gunnel line.
Please feel free to contact me if you need more help
