ClearwaterMike
- Jan 17, 2019
- C-24 C
2013 R21EC, Yanmar 3YM30, 198 hours. Max RPM 3300 in water, but experiences loss of RPM and speed after 20-30 minutes. This is a new problem, as it was operating fine last month. WOT 3300 and 8.5 to 9 MPH.
Issue:
Running Wide Open Throttle (WOT) for 20-30 min, engine RPM drops from its max RPM of 3300 to 2800rpm. once I throttle back and run for 2-5 min at 2100RPM, then throttle back up, engine then provides 3300RPM, but steadily drops back down to 2800. max speed at this rate is 6.8 mph.
Done so far: Drained and Removed fuel tank, visually inspected inside of tank (clean), reinstalled, all new fuel. Checked and cleaned breather (line, screen) - ok. checked and inspected flexible pick-up line and screen strainer, - clean and line has plenty of flow. All lines including fuel return lines evacuated, and air can easily be pulled and blew through. Fuel filter on engine replaced. system primed, no air in system. Problem persists. Fuel and fuel system ruled out?
Another note is that if continued to run at WOT even at 2800RPM the smell of diesel exhaust is overwhelming, no black smoke exiting the exhaust. Checked all hoses, no leaks.
Boat runs fine at 2200 RPM, max speet is 6.8mph
Issue:
