fishheadbarandgrill
- Jul 15, 2018
- R-29 Classic
- Non-Fluid Motion Model
- Sunfish; Vespa GTS 300 Super
- Sea Shanty
I went offshore today to discharge my black water tank for the first time since I purchased the boat. I'm familiar with macerator operations from my previous sailboat. The macerator did turn on but did not discharge any liquids (discharge valve was open). The macerator tripped the breaker on the DC panel after about 10 seconds. I unscrewed the deck fitting to see if the vent was clogged and again, no discharge and the breaker tripped after about 10 seconds. Both times the motor did run. I'm pretty sure it's been a couple of years if not more since the macerator has been used so my initial thought is that the impeller is shot and can't prime the pump. Also curious if others have had problems with the macerator priming because of it's location. Mine is mounted forward of the aft Air Conditioner. Baring any thing enlightening, my plan is to replace the macerator, although I can't believe a bad impeller would cause the motor to trip a breaker.
