S@LTD
- Jan 16, 2012
- R-21 EC
- FMLC2809G718
- Non-Fluid Motion Model
- 2004 Nautique 196
- Dynamic Duo (2018)
Occasionally when loaded on the trailer we use the macerator to empty our holding tank at an RV dump after cruising. Last week we did this on our way home from the PNW. We emptied the tank, partially filled for a rinse, emptied a second time and partially filled for one last rinse. However when hitting the switch the last time we got nothing. Tried the reset button above the rocker switch at the helm and reviewed the manual to see if there was a fuse anywhere. None were indicated for the macerator. Per the manual most water related pumps are 20 amp so started checking all of my 20 amp fuses in the 1/4 berth but didn’t see anything.
Once home I back flushed through the thru hole just in case something may have clogged and nothing changed. Before I go cutting wires to test the pump directly does anyone know if there is a fuse somewhere for the macerator?
