Main Cabin TV Replacement
fishheadbarandgrill
R-29 Classic
Sunfish; Vespa GTS 300 Super
Sea Shanty
The 18" Majestic LCD TV in the main cabin is failing and I'm looking for a reasonable substitute. Majestic's 12V TVs are ridiculously priced. I caught a thread where it appeared to indicated that RT is now using Jensen TVs. Is that correct? The Jensen TVs are a little more than half the price of the Majestic TV equivalent.
I ran across a YouTube video from Teal on SV Basik a while back where he was purchasing a regular TV that had an external transformer which converted 110 AC to 12 DC. He would then direct wire on his boat. Here is a link to the video https://www.youtube.com/watch?v=U8U-3DX3694. HE does some nice work with his rebuild. The TV he is installing is a Vizio. Check it out and do some research on the televisions for home use that may work out.
Skyworth 22" smart TV, 1080p, AC/DC fits perfect and works well, except recommend an external speaker to improve sound quality
Instead of an external speaker, you should be able to use a bluetooth transmitter at the TV that will be received by the Fusion head unit. That way you can take advantage of the installed speakers. Less clutter, less stuff.
Beardco and doke01, I was advised against using a bluetooth transmitter because of delays between the audio and video. What has been your experience? What type of transmitter did you get. Thanks and regards.
