Main Cabin TV
JeffreyAC77
Lake Union, Washington
C-302 SC
FMLT3106E415
State of Mind
I have a 2015 R-31 CB. The TV in the cabin has power (red light is on) but will not turn on. Any ideas/suggestions?
thanks,
Does your remote need new batteries? Also, power cycling the TV has worked for us, pulling the power plug from the back, waiting about a minute and then plugging in again.
John
Hi Jeffrey,
You can turn the tv on 2 ways. Normally you would use the remote. If the remote does not work there are power, channel, volume and source buttons directly on the TV. If that does not work you may have the tv set to a source that does not have a signal and would then show a black screen. Hope this helps.
Sonny
Make sure your remote has the "TV" button selected. I had to learn that one the hard way. I hope it is that easy.
I hope that helps.
Rocky
I have a 2014 31S and the TV will be on and then it just turns off without warning. I was using it to better see the fishfinder while we were drifting with the engine on, plenty of voltage per the garmin, and it just kept turning off.
any ideas for that?
Mine does the same. No idea why. Very intermittent. Sometimes will be fine for hours, other times it won’t stay on for more than ten minutes or so.
Not knowing the TV manufacture that was installed in your boats this may or may not be of use. We have a 2016 Cutwater so the same vintage as some of the post to this thread. The 12V TV in our boat is a Majestic. We were having strange operation malfunctions with the TV. Turn it on worked fine then picture would start to come and go. Turn it off then tun it on a few moments later. Sometimes it would work fine sometimes not. The sound would come and go. I called Majestic ,left a message and I did get a call back. The suggestion from the technical support representative was to install a 12 Volt power cable with high end power filter. He said they recommend using this filter when there are several 12 Volt users tied to the battery bank that the TV is powered from. An example he gave was a boat. He sent me a filter because the TV was under warranty. I installed it and we have never had an issue with this TV. We use this TV in the pilot house. We have a 26" smart TV in the V-Berth area which is powered through the inverter or shore power 120V.
Brian, is he talking about a ground loop noise suppression filter or a power rectifier/regulator? Can you post a picture of the one he sent you?
Gordon
Gordon
I copied from the web site
https://majesticelectronics.us/248-larg ... filter.jpg
The Majestic 12 Volt Power Cable with Cigarette Plug and high end filter is designed for those applications where there is major power fluctuations as well as major electrical noise. The Majestic TV's are designed to handle most cases however for those extreme environments we provide a High End Filtered Power Cable.
Majestic 12 Volt power cables are specifically designed for our TV's. Below is a list of Model numbers that this power cable is suitable. If you have a different model and cannot find your power cable simply contact us, our team is here to help you.
1M Long.
LCD Models:
15" Series TM1510 TM1530
19" Series TM1910 TM1930 TD1910 TD1920 TD1930
22" Series TD2210 TD2220
LED Models:
15" LED Series LED150E - LED151U
15" L Series L150U - L150S - L152ES
19" LED Series LED190DE - LED190DU - LED191DU - LED193GS - LED194GS
19" L Series L190DS - L191DS - L194DS
22" LED Series LED220DU - LED221DU - LED222GS
22" L Series L220DS
24" L Series L241DS
32" LED Series LED322GS
tel:561 459 1900
