serpa4
- Jun 20, 2020
- R-23 (Sterndrive)
- FMLC3051D818
- DayLo
This past month, I had two flat tires. One I didn't know till pulling over for diesel and did my routine inspection. The other while parked; it blew like a grenade! So loud it was scary.
So my boat is 2018 C30 luxury sedan (ac/gen), trailer vin number says 2017. I figure my tires are about 3-4 years old, 2820 lbs each at 80psi/10ply for 16,980 capacity. Truck stop weight ticket says my boat and trailer weighs 16,020. Not much margin!
I just bought some 225/75/15 G range tires rated at 3530 lbs (110psi/14ply) each x 6 = 21,180 capacity. I got new rims rated for more weight and higher pressure also. I feel much better with 5,180 lbs reservice weight capacity and 40% more plies, 14 vs 10.
However, based on the vin number, my trailer has a "carry" capacity of 14,000 and the trailer weighs 2,400. So, my trailer is near max rating also since the boat math says my boat weighs 13,620 packed to go, but only 1/4 fuel and 3/4 water. If I fill with fuel, I'd be over the trailer rating. I still need a dinghy, motor, davits for 250 more lbs to come.
I "assume" my carrying capacity of the trailer is based on the axles limits.
Someone said I could subtract the tongue weight off the trailer's capacity since the axles are not supporting the tongue weight, the truck is. If so, I can remove about 800 lbs and put that on the truck. My trailer thus is carrying 12,820 of its rated 14,000. So, 1180 lbs under the rating.
I guess I can also take that 800 lbs of tongue off the trailer tires also right?
Is that a good enough safety margin, 1,180 lbs?
