Marinco Spot Light Stopped Working
Dcsqatar
R-29 S
Beautiful Red
I have a 2020 R29 with a factory installed Marinco spotlight which uses the “SPLR-2 Wireless Bridge Remote” (i.e., not wired and not the handheld wireless model). My spotlight is rarely used but upon checking recently, I found it not functioning. I confirmed 12v power to the remote and took the light assembly apart to confirm all wiring, gears, etc. look good, without corrosion or water intrusion. I should have downloaded the manual first, as it described the remote/light pairing procedure. That included starting with disconnecting power to the remote. I could not fine a fused circuit which controlled power to the remote (it is not on the circuit with the “spot light”) so I dismounted the remote and disconnected its power. Repairing fixed the problem and the spot light works fine again. I thought I would share in case anyone else finds their spot light suddenly not working.
