"Check the thermostat function" under the maintenence schedule is marked with an icon. Under the maintenence schedule it refers to this icon as: ● In presence of this symbol it is obligatory to effect the technical support in an authorized retailer /workshop .....
Otherwise:
6.17 PERIODS OF INACTIVITY
Start up the generator at least once a month. If the generator is not to be used for a long period of time, carry out the following operations:
- Change the engine oil.
- Replace the oil filter cartridge (see par.6.5).
- Replace the fuel filter cartridge (see par.6.6, 6.7).
- Remove the injector and pour 2 cc of engine oil into
the cylinder and let the engine turn a few times by manually operating the drive shaft pulley.
Refit the injector.
- Replace the zinc pads (see par.6.11)
- Aspirate some antifreeze into the seawater intake
pipe in order to protect the exchangers against low temperatures, and lubricate the seawater pump impeller and the metal parts in the cooling system.
- Disconnect the starter battery and store it in a dry place (see par. 6.15)
- Disconnect the sea exhaust pipe from the engine manifold.
- Clean the seawater filter.
- Close the seawater intake cock.
- Drain the seawater from the exhaust.
- Clean and lubricate the antisiphon valve (siphon
break), if installed.
- Clean the outside of the generator, removing all dust
and impurities.
- Cover the generator with a nylon sheet and store it
in horizontal position in a dry and ventilated place.
