MASE IS 2.7 Generator wont start
Mike Wolff
R-21 EC
FMLC2846414
The Wolff's Den
I have a 2014 Cutwater C28 with a MASE IS2.7 Generator. I had not ran it for several months and it wont start. I bled the fuel line and I’m certain its getting fuel, turns over but just wont fire up. Any suggestions?
There is a butt connector on fuel shut off . Mine looked fine but wire was broken below the plastic sleeve on connector. New butt connector fired right up.
Britt
If memory serves me there is a fuse/relay that is attached to the left side of the generator as you are facing it. When we had our 27 I had to replace it when I had the same problem. I found out the solution when I called into the Mase people, I’m thinking in Florida.
Jim
