NorthernFocus
- Jun 29, 2014
- Alaska
- Website
- www.northernfocusphotography.com
- R-25 Classic
- FMLT25910808
- Divine Focus
Excuse my asking something so basic so I'll explain why I'm asking first.
I just completed only my second oil change on this engine. Last time I pulled the oil out via inserting suction tube through the dipstick tube rather than using the factory supplied drain hose. Last time I only got about a gallon (vs. 6 liters per manual) out of the engine. I assumed that was because I didn't get all the way to the bottom of the pan via the tube. Not the end of the world. So I put back in the same amount that I got out plus a bit for the filter housing to refill. Though the dipstick is hard to get a decent reading on, as best I could tell it was just a bit above the "max" line when I was done. So I ran it that way all season.
Now to present. This season I got the fittings that I needed etc. and used the hose that's installed on the side/ bottom of the oil pan. And guess what? Only got a gallon of oil out of the engine. Hmmm. Well since the stick is so hard to read and I find it hard to believe that two quarts of oil could be hiding in the engine, I went ahead and put in 6 quarts. And now the stick is definitely wet up to about half an inch onto the spring portion of the stick. So WAY above the Max mark on the stick. So now I'm wondering whether in-fact a third of the oil doesn't get pulled out through the hose or do I have a bogus dipstick?
Oh, and the boat is more or less level. Enough so to be within 1//8 in. or so across the oil pan anyhow.
1) How many of you use the installed hose to drain the oil? If you do, how much oil do you get out and put back in?
2) Can you read the dipstick? Even after sitting overnight, mine is difficult to read, i.e. smeared wet to the top with no clear level line. Though not truly wet to the top as now). With the level up onto the spring portion it is pretty easy to see. I also verified the level by running a piece of poly tubing down the tube.
3) Wondering if I have a bogus dipstick, I'd appreciate it if someone could measure theirs from tip to the "seat" that it rests on top of the tube when fully inserted and post result. And from tip to Max line on stick.
